Originally Posted by
JerseyBill
I am getting poor cut quality using the fine cut nozzle on 11 Gauge steel (.125). The cut has a scalloped appearance ( I will attempt to attach photos). The equipment is PowerMax 1000 with machine torch. It is used on a Torchmate 3. Generally I get good quality cuts using 60, 40 and fine cut nozzles. But most of the parts have been large and have more straight lines in the design. The parts I am having problems with are much smaller and have more curved lines in the design. The settings are 50 Amps, 83 Arc Volts, 90 IPM. I have tried changing settings such as air pressure, speed and pierce height with no improvements. I have also tried changing ramp speed and continuous contour speed. I have checked the gears for loose set screws etc. and checked the air supply. The original file was done in Rhino and exported as AI for toolpathing in SignLab. The file seems to be free from excessive nodes and is real clean. I've completed many projects using the Rhino to SignLab path and either AI or DXF as the file type with no problems. But they have all been larger parts with straight lines or very large curves. Any suggestions?
