With a Torchmate 3, ATHC and a Hypertherm 1000, I have been getting scalloped cuts especially when cutting small parts using thin metal (.125"). Jim Colt suggested that I check the machine movement. So I attached a felt tip pen to the torch and ran the cut file. The result is attached. All of the drive components are tight with no play or slop. But the pen line shows the machine is not plotting a smooth curve. This is also exactly reflected in the cut metal. How can I fix this?
