I hope this is the right forum to ask. I'm going to cut my first fixture using a microcarve MV3. I've got a cheap HF router on it (28K rpm) with a 1/8" carbide spiral bit. I will be cutting 1/2" plywood in multiple layers (0.1" at a time).
The main square is to hold a plastic enclosure. The top and bottom squares are finger grooves for case removal. The left and right pecks and to mount toggle clamps, and the corner holes are for a 1/4-20 bolt to mount it to the table.
Any recommendation on the feed rate and plunge rate? Is 0.1" per pass a good number to use?
Alan
