585,589 active members*
3,668 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Finding correct machine type
Results 1 to 3 of 3
    Nov 2011
    I am a bit of a newbie and was hoping someon might be able to help with which machine type I need to nominate in Mastercam X5 for my mill which has been fitted with Acurite Millpower to operate as a 3 axis machine.
    As I understand it this will determine whether generated G Codes will work. I have been generated code with Edgecam but am wanting to swap over top Mastercam.
    Cheers
    May 2004
    4519
    Your distributor should have helped you set this up. Does the Acurite Millpower use Fanuc style code?
    Nov 2011
    Used Fanuc3X when first trued Edgecam and it kept crashing when running the code. A friend helped with Feeler 3axg17.mcp and that has generally worked well.
  1. help finding a machine
    By nat45928 in forum Commercial CNC Wood Routers
    Last Post: 09-02-2011, 06:32 AM
  2. Need help finding a machine
    By MikeR4453 in forum Hobby Discussion
    Last Post: 07-26-2010, 06:39 AM
  3. Replies: 4
    Last Post: 04-18-2010, 05:19 PM
  4. Finding the format type?
    By KSDeerSlayer in forum Fadal
    Last Post: 10-05-2007, 03:51 PM
  5. Help finding the right machine
    By Jay Kyle in forum CNC Machining Centers
    Last Post: 02-06-2007, 08:00 PM
