I recommend you look at Microcarve. Very low cost and perfect for non-metal cutting. An area of concern is cutting carbon fiber, though. Extraction of particles will ne critical.
Originally Posted by
PaulMakesThings
Hello,
A past professor of mine has asked me for advice on a machine for his lab. He probably asked me because I'm a mechatronic engineer now. But I don't work with mini CNC's and don't know which ones are good.
here is what he needs:
-Small footprint
-Can cut samples out of flat sheets of plastic and fiber composites including carbon fiber, doesn't need to cut metal
-6x6 inch work area at least
-he hasn't specified but I'm guessing he can afford something in the $5K range
-limit switches, other protections a plus
Since he just needs to cut little samples from sheets of composite, I'm thinking he just needs a little engraver/cutter, above all it must be easy to use. I can't teach his students how to use it, I might help install it but that's it. So the more intuitive and reliable the better. I'm familiar with sherline mills, but those don't even have limit switches or homing, and I'm certain the students would be crashing through the clamps and the bed constantly. I think something a little more narrow in its use which just cuts sheets would be better.
CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
