I need the following parts made. These would be a small batch initially for a nearing final version of a prototype/early production assembly I am working on.
Sorry for drawing it in paint but It was a quick and dirty sketch but they are also very simple parts.
Dimensions are as listed in the drawing or:
x.xx" +/- .010"
x.xxx" +/- .001"
Part #1 I am calling "Aluminum Tube" even though it starts out as an Aluminum round bar. See picture below:
Quantity: 15 to start
I would like to have them sent to me finished annodized but if you do not have that capability that is fine I have sources. Quote it both finished and plain if you can do annodizing.
Part #2
I am calling "Counter Weight". It does not have to be terribly precise as it mentions is a counter weight. It essentially is round bar of steel with a 5/8" hole through the center. With an 1/4"-20 set screw hole going midway through the side into the center hole.
Quantity: 10 to start
This needs to have a smooth bur free finish. I would like this powder coated but I can have powder coated locally if you do not have the capability. Quote both ways if you do have capability.
If they work and sell as well as I hope they do then this will likely turn into a reoccurring order.
You may quote either part individually or combine them together. I would prefer to deal with one supplier/machinist if possible. Please include shipping to 44224.
Thanks.
Send PMs for quotes.
