Hello All, this is my first post, so please be gentle.
So I''ve decided to take the step into building my very own 3-axis CNC system and am looking for a bit of advice. I have read through many posts but I'm still unsure of what to do as everyone's build and situation is a bit different.
Okay, so I'm keeping in mind my budget, trying to get the best bang for the buck, without compromising too much.
So I started off looking first for linear drive systems and saw an Ebay ad that was a complete xyz package, 3' x 2' x 1' respectively. ~$280 shipped OBO, it includes what looks like everything needed; rods, bearings, mounts, etc. After pricing out each individual item seperately to others on Ebay, the price seems decent especially since you can send an offer.
Next, I've chosen to go with a 1'2"-10 5 start SS threaded rod for all axis, and anti backlash flanged nuts.
I intend to build a completely mobile gantry to conserve some space as the above dimensions are quite sufficient for any of my intended purposes. I'll more than likely build it with aluminum. I will be using my 2hp rated router that I already have ~10-15 lbs. Of course I'm not too sure what the total weight of the gantry will be at this time.
I'm going to use stepper motors and er lies my next question, what size motors would be sufficient for this type of setup? I'm looking at the cnc kits that keling aka automationtech has to offer. I've decided to go with the Gecko G540 all-in-one solution as the brains. Essentially, would it be over kill to have all 3 motors as NEMA23 size ~480oz, or would i need larger ones?
Also, I've noticed some kits with 1 motor being larger than the other two. Not sure if that's for the x-axis to compensate for moving the gantry, or for the z-axis as it needs to lower/raise the router/spindle. If for the x-axis, should I consider the motor for that to be the only larger one?
That's it for my initial questions. I appreciate any advice anyone can give.
Thanks!
Marc
