I have a nice linear 42V pwer supply that I want to run my cnc controller system with and I wondered if any of the electronically inclined out there could give me some tips on the best way to take the 42V DC output and pull off 5V (2amps) and a 12-30V (5amps) legs. ( I need these legs to be stable and not likely to introduce spikes, ripple, or other anomalies into the circuits--this is a priority! so don't be afraid to suggest caps and filters where needed) I know that you can use linear voltage regs like the 7805 and the LM 317 but these are rated for less voltage than my linear supply provides. I also have heard that you can reduce voltage stepwise by adding diodes in series. However, this is not what I'm looking for because to reach 5 v from 42... well, you know. So I am aware of some less than ideal options but I'd like to do this right so I need some experienced and seasoned advice here, if someone would be so kind to provide it. I have a great deal of current and olders linear and digital components that I can pull from to do this project so don't be afraid to suggest unusual components or approaches.
all of this is a learning experience.
Best regards and thanks in advance for any and all help.
Keith
