584,837 active members*
4,895 visitors online*
    Mar 2012
    stepper motor speed
    OK
    Is it possible to control the stepper motor speed through program or it is always constant?
    Thank you
    Jan 2010
    2141
    The stepper motor speed depends on the rate at which step pulses are sent to the motor driver (as well as the design characteristics of the motor driver). So, that speed would usually be controlled by a program. More sophisticated programs will handle acceleration, constant speed, and deceleration of the motor, while less-sophisticated programs may use a constant speed.
    As the motor speed is increased, the torque available from the motor will decrease. The data sheet for a specific motor should include a graph showing typical torque vs. speed curves. There are other factors which could affect the speed of the motor (for example, resonance).
    Mar 2012
    Do you thing then that it is better to use servo motors as they don't loose torque force even if the speed is increased
    thank you
    Jan 2010
    2141
    The choice would depend on many factors, including the specific requirements of the application.
  1. Stepper motor speed unstable!?
    By MACKAY9999 in forum Torchmate
    Last Post: 03-05-2008, 09:28 PM
  2. Stepper motor max speed?
    By Labidus in forum Controller Cards
    Last Post: 02-23-2008, 06:11 PM
  3. Low stepper motor speed
    By MagooT in forum Stepper Motors / Drives
    Last Post: 11-08-2007, 05:10 PM
  4. stepper motor speed
    By AlanETM in forum Stepper Motors / Drives
    Last Post: 01-06-2006, 04:17 AM
  5. stepper motor speed question from newbie
    By designit in forum Stepper Motors / Drives
    Last Post: 10-04-2005, 02:25 PM
