585,880 active members*
6,672 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > tool measurement h and d offset tool page
    May 2012
    does anyone know how to measure tools, and use the same number for both the h and d offset? have a mori with a fanuc 525 control. nothing really different same as other fanuc controls. i dont mean touching every tool used in a program off the top of the part , i am referring to actually measuring the tool. the tool will have a positive value from the spindle.there r only 100 tools that can be stored in the tool page. i have more than that. need all the space i can get rather than clutter the whole page with d and h offsets. really need a page for both. any help?
    Apr 2006
    3206
    Set up a "library" of tools, say 90 thru 100, that are standard type description that you can change. Use a macro that addresses a specific tool in that library and changes it to what the particular tool you're using has as its D and H.
    .... Say you've got a 1/2"dia endmill in 92, but the tool you want to use is undersize or maybe metric, have the macro go to tool 92 and subtract the difference between the real tool and the library value. Have the program reset the value to the preset library value at the end, so next program everything's back to default values.
    This way, your tooling options are endless, and all you need is to write a handfull of macros that you can plug in, and a list of the default values to refer to.
    Tool
    #90 = face mills
    #91 = drills
    #92 = endmills
    #93 = chamfer cutters
    #94 = taps
    .....and so on.
    All this predicated, of course, on your Fanuc having macro capability.
    Apr 2002
    5003
    If it's possible I would make a toollist at the beginning of your Prog, that writes the r and l into the desired toolnr. In my big programmes I make it as well with the programmline where the tool is called.
  1. Easy part counting using tool offset page.
    By djc1965 in forum Haas Mills
    Last Post: 02-27-2012, 08:18 PM
  2. Mitsubishi Meldas - Switching Tool Offset Page Type
    By avongil in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-18-2008, 08:20 PM
  3. Display Absolute on tool offset page
    By billm in forum Fanuc
    Last Post: 02-14-2007, 09:12 PM
  4. NC reading tool length from offset page, not data page..?
    By RMagnusson in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-21-2006, 11:07 PM
