585,766 active members*
4,469 visitors online*
    Sep 2011
    5
    Another DXF to G-code Project
    Hi everyone
    I've just started my CNC project for graduation thesis, I'll create a simple CAM software to assist manufacturing on CNC milling machine, it'll be useful when you work with simple cutting contour, it's also free and light. The soft is programmed on VB.net
    DXF to G-code is a module of the software. This module reads the data from dxf (Autocad Drawing eXchange File) and convert them to NC code. Up to now - in the first stage of the project, it can read a closed contour created from Lines and Arc.
    If you like this, you can download to test it and give me some comments, i'm very glad :cheers:.
    - The module is being improved so there are a lot of bug. I'll try to fix them and add more features such as:
    + Read ellip and spline curve
    + Cut off all the material out side or inside the contour.
    + Add Blank Properties and cutting parameters.
    + Fix unworking function (zoom, pan, preview...)
    + Add cut layers for cutting to a depth...
    I'll reupload the soft when finished adding new features. Sorry for my bad English
    Thank you all!
    This is some screenshot:
    Contour with lines
    Contour with lines and arc
    Test the generated toolpath on CIMCO Edit
    YOU CAN DOWNLOAD THE ATTACHED FILES HERE
    Attached Files Attached Files
    Sep 2012
    Smile DXF TO GCODE
    I Like Your program. I would use some of your basics to implement in my sofware for wire EDM. would it be possible to post the code ?
    best Regards
    Boenke
    Sep 2011
    5
    Quote Originally Posted by boenke View Post
    best Regards
    Boenke
    :cheers:Thank you for your interesting, surely I'll post the "contour" code, I think it's enough for an EDM machine. The code is written with VB.net 2010, hope it work.
    Sep 2011
    5
    A newer built with:
    - Zig rough milling outside contour
    - Blank setup
    To use this:
    - Step 1: Select dxf file (dxf has lines only, i'm still working with arcs)
    - Step 2: Define blank in Blank Setup tab
    - Step 3: Input tool diameter
    - Step 4: Input stepover (width per cut) (less than tool diameter)
    (other features are not done yet, so skip them)
    - Step 5: Press generate Button
    Demo (generate and verify tool path):
    [ame=http://www.youtube.com/watch?v=_WJjJkk-cYQ]DIY - 2D CAM SOFTWARE - DXF to Gcode - YouTube[/ame]
    Jun 2022
    Re: Another DXF to G-code Project
    project code?
  1. Free G-Code Project File Downloads
    By W4MWK in forum Hobby Discussion
    Last Post: 10-21-2013, 10:42 PM
  2. Replies: 4
    Last Post: 03-29-2011, 02:39 PM
  3. Converting Fanuc G code to Seimens 840D G code
    By Jasbinder in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 02-20-2011, 05:02 PM
  4. Replies: 8
    Last Post: 12-15-2010, 09:32 PM
