585,763 active members*
4,232 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Parallel port add-in card.
Results 1 to 8 of 8
    Feb 2009
    1290
    I posted this in the Mach3 forum but I realize now that this is the correct form. I have a G540 and a G203V, I need an add-in parallel port. I would like to get a dual card if possible, if no has an opinion on the card listed below maybe a link to a known good card would be helpful.
    2 Port PCI Parallel Adapter Card - EPP/ECP | StarTech.com Canada
    Thank You.
    Feb 2009
    1290
    Thanks for the link Gerry, however from the picture I noticed it is a 5VDC card (I can tell from the number of slots) Most newer computers will not accept this type of card as they require a 2 slotted card (3.3VDC and 5VDC)
    The computer I have needs a 2 slotted card, startech makes a dual voltage card here.
    1 Port PCI Dual Voltage Parallel Adapter Card | StarTech.com Canada
    Another question would be, what logic levels do the Gecko products work on. Will they accept a 3.3VDC as a logic level HIGH?
    Thank You.
    Apr 2004
    135
    You are correct that the parallel port card sold by PMDX is a
    5 volt PCI bus card. If you have a machine with a 3.3 volt bus,
    it will not fit. However, I disagree with your statement that
    most modern motherboards require dual slot 3.3 volt PCI
    bus cards. Looking just now on NewEgg, I had a hard time
    finding any motherboards that require the dual slot PCI
    cards. For a while the 3.3 volt dual slot stuff was popular
    for servers and high end graphics machines, but they have
    actually faded away as time passed.
    The newer Geckodrive G201X and G203V drivers will run
    from 3.3 volt signals. Some older stand alone Gecko drivers
    require stronger signals. The G540 requires that the port
    be in EPP mode or otherwise configured to provide higher
    drive current on control output signals. It is this latter
    requirement that caused PMDX to offer a modified parallel
    port card.
    Regards,
    Steve Stallings
    www.PMDX.com
    Quote Originally Posted by Drools View Post
    Feb 2009
    1290
    Thanks for the reply Steve. I didn't want have to purchase a new Motherboard for the machine. My assumption was incorrect as you point out. My G50 and G203V was purchased within the last year so I hope the 3.3 volt card will work.
    The one computer I have on hand is a Intel SR1450 1U server, with Dual Zeon processors. This and a Rackable 1U server was given to me so I figured why not give them a try. Both machines work with WinXP but only take the 3.3Volt cards. The other machines I have available are based upon Intel motherboards but they are in use by my boys and I would have to build them new ones if I were to steal them away.
    I will give the startech card a try, unless there is a different 3.3 volt card known to work with the G203V and G540.
    Thank You.
    Apr 2007
    1955
    Is there a way to tell a 3 vs 5 volt board ?
    The reason I am asking, is that I am thinking of a 2 x 540G using the PMDX.com dual parallel port card setup.
    For instance these two boards at newegg - there is nothing in the product description about 3 vs 5 volts.
    Newegg.com - BIOSTAR A880G+ AM3 AMD 880G HDMI Micro ATX AMD Motherboard
    Newegg.com - BIOSTAR A880GZ AM3+ AMD 880G HDMI SATA 6Gb/s Micro ATX AMD Motherboard
    The second board actually is the updated version with AM3 support.
    I am thinking of using it with linuxcnc.
    Harry
    Feb 2009
    1290
    yes a 5volt card has only 1 slot in the gold finger section that fits into the motherboard, while a 3.3/5volt card has 2.
    If I'm correct the 2 slots configuration, means it supports 3.3 and 5 volts not that they are 3.3 volts only.
    Thank You.
    Apr 2007
    1955
    Thanks for the answer, but I am still confused.
    Does this mean I can buy most any motherboard, and the PCI card parallel ports will output 5 volt TTL logic ?
  1. PCI parallel port card
    By Smooth90 in forum LinuxCNC (formerly EMC2)
    Last Post: 12-13-2011, 05:17 PM
  2. Which PCI parallel port card?
    By bead in forum CNC Machine Related Electronics
    Last Post: 07-03-2010, 07:32 PM
  3. PCI 1 port parallel card
    By noyloj in forum Machines running Mach Software
    Last Post: 12-03-2009, 12:22 AM
  4. PCI Parallel Port Card
    By Adamj12b in forum Mach Software (ArtSoft software)
    Last Post: 12-23-2008, 04:03 AM
  5. pcmcia parallel port card ?
    By WsW-WYATT in forum DNC Problems and Solutions
    Last Post: 09-07-2005, 12:29 PM
