I have finished the fixture to assemble the handle bars. It will hold all the brackets in the proper
place and hold the bars at the correct angle for assembly. I will also be able to drill the holes for
the front axle thru the blocks to correctly locate them.
You can see why it's going so slow. My fixture to mini bike ratio is pretty low.
Man that's nuts!
What's the expected production quantity of bikes you will be making?
Made some forward progress today. Got the forks about 80% done. Forward motion today!!
Made the die to crimp the forks down by the axle. Works well and is almost exact to the real fork. I tested it on a scrap piece of tube and it looks good. The crimp is not exactly centered because I was too lazy to drill the tube to pin the die before testing.
That is too freakin cool! Love it!
Obligatory Zoolander quote, "What is it? A bike for ants?"
Can't wait to see more of this project,
Ian
It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
I'll have to remember the die crimp trick. Nice job!!!
The die worked perfectly. The frame is done! Now I can move on to something else but I am not sure which way to go.
That looks really GOOD!
I take it you will be building motor from scratch also?
Ah come on put the Demon in that sucker
Great work very impressive what type of power plant?
Lou
http://www.cnczone.com/forums/diy-cnc-router-table-machines/140832-cnc-software.html
4 stroke ?
