I am working on a Emcoturn CNC lathe conversion from the original control over to Mach3 and servos with Gecko drives.
I would like some advice on what would be the best wire and gauge to run from the drives to the servos.
The servos are rated 870 oz in-80v-7amp const-30 amp max
I just need some type of shielded cable from drive to servo,no encoder wire
Also wire from VFD to motor using a x200 Hitachi with a 5 hp motor.
Thanks for the advice in advance
