HT's setting may or may not even get you in the ballpark. Also are you sure your cutting the right direction? We have customers who build from our CNC gantry kits and go from just hooking up their plasma to a 20,000 line program scene and expect perfection without any testing of speed and amperage. Do some line and circle test with different tip volt settings, amperages and speeds to determine what works best with your plasma system. The other thing to consider is if you are using the hand torch tip you will not get good height readings...meaning you may drag the tip at the tip volt preset that works best. If you are using the hand torch switch out the tip for the machine torch consumable.
Now featuring Plasmaland online
