Hi Guys Hope you are all making chips today. Our HAAS Sl-20 had a monitor melt down. I ordered one in UPS Red Saturday delivery and it's not exactly the same. This is no surprise as they are changing all the time. It came without any instructions. The old one is basically a frame with two cables. These cables attach to a board mounted in the control housing. The new LCD is mounted in the same frame but has two boards inside the frame and two cables coming from it. It's easy to see were some of the original cables will go but I cant tell were these other two cables are going to plug into the existing board inside the control housing. Has anyone installed a new HAAS replacement recently. I need the machine running.
Thanks Ron
