585,743 active members*
5,136 visitors online*
Thread: Cut2D
Results 1 to 10 of 10
    Dec 2010
    61
    Cut2D
    Before I purchase, I was just wondering what are some opinions of Cut2D??
    Sep 2011
    1183
    The new Cut2d 1.5 is good a lot better than the old version but it does not compare to VCarve Pro 6.5 you can download the free trial of all Vetric software and see which suits your needs..
    Lou
    http://www.cnczone.com/forums/diy-cnc-router-table-machines/140832-cnc-software.html
    Sep 2009
    1856
    depends on what you wont to do try free trails first
    Aug 2010
    17
    Free Trail
    It seems to be nice, I have been thinking about buying it but the trail does not allow me to save a toolpath, not even once to actually cut something to make sure it works for me.
    Jan 2008
    940
    There are samples that you can cut you can modify some objects with node editing to see how it will cut. You can create something and save it once you purchase cut 2d or v carve pro aspire you will be able to make your cut file
    Aug 2010
    17
    bought it
    Quote Originally Posted by fixtureman1 View Post
    I just purchased it this morning and we will give it a try, can this be installed in two computers? the design station and the production station connected to the cnc router?
    Jan 2008
    940
    Yes you are allowed to install on both computers I have it on 4 of mine the agreement says as long as you own the computer. I have a design computer in my house and one in my shop also it is on my laptop and my control computer.
    May 2011
    180
    I have been using SprutCAM for about 2 years. I was attempting to get the high school students on my FIRST robotics team up to speed on how to use it. Many little issues kept them from being productive with it. About 2 months ago, I bought Cut2D in hopes that it would be easier for them to learn.
    They were able to start making parts after about 20 minutes of playing with the program. Of especially outstanding quality is the automatic tabs function. It has saved them hours of frustration in setting up parts. SprutCAM doesn't do a very good job with tabs. In Cut2D, it is just as easy as it could be and is worth the $149 in just saved aluminum parts that didn't get fixtured correctly in Sprut.
    Only downside is it is missing some of the nice bits of a full featured program. You can't do tool changes in the same program. Yes, you can layout multiple tool paths, but you will have to save each tool's GCode into a seperate file. Not that big of a deal, but a rather odd restriction that is purely a 'buy the other version' trick. It also doesn't handle coolant options, so you have to turn your coolant on manually.
    I would highly recommend this program if you need a fast/easy program for doing a lot of good things in 2.5D milling.
    Jan 2008
    940
    What type cnc are you using? There may be an ATC post for it or if you can email Vectric they may be able to write one for you.
    No, Cut2D does not allow toolchanges. As he said, you need to move up to V-Carve Pro for ATC ability.
  1. CUT2D questions
    By cornbinder23 in forum Vectric
    Last Post: 02-18-2011, 01:20 AM
  2. What CAD to get for Cut2d?
    By forrest39 in forum Vectric
    Last Post: 10-30-2009, 04:45 PM
  3. Cut2D - Can It Do this?
    By noisillator in forum Vectric
    Last Post: 06-19-2009, 05:43 PM
  4. Cut2D
    By voltsandbolts in forum Vectric
    Last Post: 04-27-2008, 04:35 AM
