585,971 active members*
4,250 visitors online*
    Aug 2010
    75
    Kasuga Mill Control Swap Retrofit
    So I got a Kasuga Mill in the shop around 3 weeks ago. I have been asking alot of questions on the Mach forum and decided on going with the current DC Servo drives w/ KFlop & KAnalog. I just got the boards this week and mounted them in an old tower. I have been having a hell of a time finding out any information on the bandit control. However some1 was nice enough to help me with a pdf manual for the NC400 DC Servo Controllers. It also has a Quickdraw tool changer which is the only thing I have seen actually work. The bandit has a bad power supply and I really don't feel like spending nearly $400 replacing it. The spindle motor does not power on. I think I'll run some tests tomorrow with the volt meter.
    So my first question is how much PSI does the Quickdraw require to operate?
    Second question is do I need the bandit control at all or can I remove that old brick and have my computer with Kflop & Kanalog handle everything? From what I could gather from my volt meter tests inside the bandit control was that the transformer for the power supply has power going in and nothing coming out. Could I just replace the transformer and see if it works?
    Many more questions to come. I am really in no hurry to finish the project because I want to do it right but I really would like to start making some progress.
    Re: Kasuga Mill Control Swap Retrofit
    Quote Originally Posted by K_Labs View Post
    Have you solved the problem on your machine?, it seems I have the same issue in mine, probably same machine, my controller has a power supply malfunction (has a cracked housing), but still works, my main spindle motor also does not work, I had conected it directly to my 3 phase 220v power lines, and works just fine, by any chance, do you have any user manuals by now?
  1. Kasuga NC mill to CNC?'s
    By K_Labs in forum Knee Vertical Mills
    Last Post: 03-03-2023, 12:06 AM
  2. CNC Mill Control Retrofit Recommendations
    By iaknown in forum Controller & Computer Solutions
    Last Post: 02-23-2011, 03:46 PM
  3. Replies: 20
    Last Post: 06-08-2009, 02:46 PM
  4. Kasuga mill with Summit Dana control
    By Bob fran in forum Uncategorised MetalWorking Machines
    Last Post: 10-02-2004, 07:52 AM
