585,760 active members*
3,898 visitors online*
    May 2012
    Question Erratic Z movement AND NO X Y MOVEMENT
    I wired up a new system with nema 34 motors, 3 axes, Power supplies, drivers, bob, etc. Wiring diag is att.
    I can jog the Z axis pos/neg but It studders and the movement is not smooth.
    The X and Y axis will not move at all. The wiring is identical (except for
    pin assignments to the BOB)
    I have config'd the "motor tuning" exactly the same on all 3 axes, and the homing and limits are all the defaults -100 & +100.
    I'm also a little unsure of the dip switch settings on the drivers. The vendor who sold me the: motors, 24v ps, drivers and BOB, shows the following:
    nema34, 872 oz-in, 15mH, 2.0a rms & 2.6a peak, 6.4v eight wires
    I've set the dip switches (1-8) as: on on on on on on on on
    which is 2.0 a rms,full current,400 pul per rev.
    Any Ideas would be welcome.
    Terry
    Attached Files Attached Files
    Dec 2010
    33
    change your step size down to 50, and try again, also check your acceleration settings, they really should be between 2 and 5 times the velocity setting.
    Ex Emach Service Engineer, contact me for assistance.
    May 2012
    Erratic Z movement AND NO X Y MOVEMENT - part2
    Thanks for your reply Wombilly. I set the steps from 1000 to 50, changed the velosity from 600 to 100, and changed acceleration to 200.
    NO CHANGE - EXACTLY SAME BEHAVIOR.
    terry
    Jan 2008
    40
    Troubleshooting
    Is the problem electrical or mechanical?
    Disconnect the motors from the unit and then run them. If the motors spin, then you have a mechanical issue (likely caused by binding from misalignment).
    If the motors do not spin, then your problem is electrical. Use a multimeter and double check your input and output voltage. To ensure that Everything is working properly.
    What make/model are the drives?
    P.s. the dip switches could be network node mapping and if all three are set the same, only one will work. You might need to change them. The manual for the drives should be able to help you with these.
    Dec 2007
    85
    Controller Software
    Sounds like you don't have your software controlling the proper pins if you are using a parallel port.
  1. No movement after G00
    By slatronic in forum Mach Software (ArtSoft software)
    Last Post: 07-03-2012, 02:10 AM
  2. no x y z movement
    By bullseye in forum CamSoft Products
    Last Post: 07-29-2010, 02:39 AM
  3. G02 but X Y Z movement
    By PEU in forum G-Code Programing
    Last Post: 02-19-2010, 12:06 AM
  4. No Movement
    By wishmasterg in forum Mach Mill
    Last Post: 02-15-2007, 01:39 AM
  5. Erratic movement on steppers - need help
    By maxxgraphix in forum CNC Machine Related Electronics
    Last Post: 06-12-2005, 01:43 PM
