Hi all
I am running Mach3 with soft limits at the moment as I do no have home & limit switches yet and find a "problem" when switching between G20 & G21. If I set my machine up in imperial and run metric gcode I get soft limit warnings when starting. Is mAch supposed to refactor things like soft limits when running code opposite to the machines default?
I could run the machine in metric and load G20 based gcode but then my soft limits wouldn't work (except maybe zero) so I was hoping there is a "switch" somewhere that I haven't seen yet that tells Mach to adjust all measurements and settings when running a particular sort of gcode.... is there anything like that?
If there is nothing then I suppose until I get my switches in place it would be easier to run 2 different profiles, one for metric based gcode and one for imperial based gcode....
Hoping someone could clarify what there is or isn't in Mach.
Cheers
Bruce
