585,992 active members*
5,238 visitors online*
Thread: DIY Spindle
Results 1 to 7 of 7
    Nov 2011
    DIY Spindle
    I'm thinking of making a diy benchtop mill, so I started in CAD with the spindle. I made a simple spindle with pillow blocks, and an er25 collet, and a 1hp motor. Will it be solid enough for milling steel? Here is all the parts I plan to use.
    ELECTRIC SCOOTER BIKE 750 WATT 1 HP DC MOTOR.. | eBay
    KML UCPE204 20mm 2 Bolt Pillow Block Bearing UCP 204-20mm Set Screw Locking | eBay
    ER25 Straight Shank D20-150L Milling collet Holder -US | eBay
    Attached Thumbnails Attached Thumbnails Front Pic 3.PNG   ISO Back Pic 2.PNG   ISO Pic 1.PNG   Frame and Spindle.PNG
    Apr 2005
    419
    No, I suggest you read up on bearings for spindles. I would be surprised if such a spindle could even do a decent job on aluminium.
    You need at least a pair of AC bearings, and generally you would see a pair of AC with a deep groove in the back, or two pairs of AC. The preload is important as well.
    Jun 2010
    1414
    Looks sexy though. is that 2x2 square tube steel?
    Nov 2011
    Quote Originally Posted by nateman_doo View Post
    I took a look at these angular contact bearings, I see that they are mean't for radial loads so they should do better.
    7204 Nachi Angular Contact 20x47x14 C3 20mm/47mm/14mm Steel Japan Ball Bearings | eBay
    Nov 2011
    Here's a rendering of my design I'm working on the saddle, and I changed the spindle by using angular contact bearings inside a turned aluminum housing.
    Attached Thumbnails Attached Thumbnails Benchtop Mill Pic 1.PNG   Spindle Housing Section Veiw.PNG
    Feb 2006
    7063
    I'm baffled by this.... As drawn, it appears you have HUGE Y axis travel, but the spindle is set so far back, it appears only about the rear-most 1/3 of that travel will be usable, as the table will be forward of the spindle for most of its travel. Maximum usable travel will be roughly twice the distance from the rear edge of the table when it is as far back as it can go, to the spindle center line. Any additional forward travel will be pretty much useless.
    That tubing framework looks to me like it would have very little torsional stiffness.
    Your spindle design will NOT work well at all, doubly so with an aluminum housing. When the spindle heats up the bearing pre-load will increase due to differential thermal expansion of the housing (which will expand a LOT), and the (presumably steel) spindle (which will expand FAR less). The two A/C bearings should be back-to-back at the bottom of the spindle, with a single radial bearing at the top, with a slip-fit to the spindle, so thermal expansion does not affect pre-load.
    Apr 2010
    294
    I quite like your generous Y-travel. No use at all for actual milling, but it will allow you to bring the table out into clear air for setting up. Perhaps if you repositioned the bracing for the column you could get the table to travel right to the back of the machine and have even more!
    You don't seem to have much stucture in the main bed - it's all in the column. Are you going to bolt this down to something that will add rigidity?
  1. Mini Mill X2 Spindle Head + VFD + Chinese Spindle= custom!
    By diyengineer in forum Uncategorised MetalWorking Machines
    Last Post: 12-26-2016, 10:04 PM
  2. VistaCNC iMach 3 Spindle Tachometer causing inconsistent spindle speed
    By QueueJr in forum Uncategorised MetalWorking Machines
    Last Post: 07-03-2012, 01:46 AM
  3. 1992 VF2 Alarm 123 spindle Spindle Drive Fault
    By dafowfidy in forum Haas Mills
    Last Post: 05-14-2012, 07:32 PM
  4. mach3 spindle dro not working, spindle speed changing while jogging and running code
    By jasminder in forum Mach Software (ArtSoft software)
    Last Post: 02-23-2011, 07:12 AM
  5. Replies: 4
    Last Post: 10-15-2010, 07:10 PM
