585,982 active members*
4,690 visitors online*
IndustryArena Forum > MetalWorking Machines > EMCO CNC Machines > EMCO Mills > Vmc-100 tm02 problem , Lines on monitor
    Jun 2012
    8
    Hi!
    I just got a strange problem with my emco vmc100 with tm02
    Controller. When i was transfering some serial data it suddenly
    Frooze. When i turned it on and off all i get is horizontal and vertical lines on the monitor?
    I can't do anything. I ve opened the back piece and pressed the
    Reset button without sucess. Anyone has any idea of how this can be solved?
    Aug 2012
    I have the exact same problem. Have you found anything?
    Jun 2012
    8
    Yes. I had to remove the backup battery and re-install the MSD.
    Sep 2020
    5
    Re: Vmc-100 tm02 problem , Lines on monitor
    Quote Originally Posted by dahlman View Post
    By chance, may I have a copy of you MSD? I recently purchased my VMC-100 and am in need of reloading the parameters.
  1. Having a problem with the monitor on a 2000 VF3.
    By Eric MFG in forum Haas Mills
    Last Post: 03-30-2012, 02:27 AM
  2. Biesse 336 monitor problem
    By sercab1 in forum CNC Machining Centers
    Last Post: 02-24-2011, 08:02 PM
  3. PRoblem seeing dxf lines
    By Ed_R in forum SheetCam
    Last Post: 03-25-2006, 10:32 PM
  4. Problem with OM Monitor/Display
    By darrylh in forum Fanuc
    Last Post: 01-14-2006, 01:04 AM
  5. Monitor problem
    By cncadmin in forum Mach Software (ArtSoft software)
    Last Post: 02-28-2005, 04:51 PM
