Not sure if I had to post this question to different part of the forum, so please, Administrator, if needed move it where right to sit,
I'm a 1 year newbie in the world of cnc machining, need to consult you about upgrading my machine with a new spindle, with the following detail:
I have this machine (standard Chinese 6040 cnc machine off Ebay):
http://i47.tinypic.com/dt92e.jpg
but my machine is older version and came with a simple spindle of air-cooled type.
I'm going to buy this spindle:
1.5KW WATER-COOLED MILLING AND GRINDING SPINDLE MOTOR WITH INVERTER DRIVE VFD h5 | eBay
which is (claimed to be) 1.5kw, water cooled spindle with this specifications:
Spindle:
1) Diameter: 80mm x Length:188mm (including air interface: 80mm X 203mm)
2) Power: 1.5 KW
3) Voltage: 220V~250V
4) Frequency: 400 Hz
5) Speed: 8000-24000 R/min
6) Water Cooling
7) ER11(3.175mm,4mm,6mm) collet chuck
8) Runout off: less than 0.005mm
9) Grease Lubrication, Technical Parameters for Variable Frequency Drive
Inverter
1) Inpute Voltage: 220±15%
2) Output Voltage – 208-240VAC (analogous to Input Voltage)
3) Inpute Frequency: 48-63 Hz
4) Outpute Frequency: 0-400 Hz
5) Inpute Phase: suit for 1 phase input, and also suit for 3 phase input
6) Outpute Phase: 3 phase
7) Item Manufactuer: From a well-known manufacture who manufacture VFD for more than 12 years.
8) Warranty: 2 years
Diameter and mounting:
One problem is that my old spindle is 56mm, I need a mount, they sell it for around 70$ and want a shipping of 120$ to me from China! I thought may be to make one out of aluminium myself, by my current spindle, then replace the spindle, is that practical? any idea / comment please?
Water pump, DK-4000:
The seller suggested this water pump:
4M Water Pump/spindle motor water-cooled circle pump | eBay
which is (claimed to have) this specification:
Submersible pump,
freq.: 50Hz
power: 85W
H.Max: 4M (don't know even what this is!)
F.Max: 4000L/H (don't know even what this is!)
Also around a 100$ cost for it, is it reasonable to buy? better options that experienced people may choose?
