Keep CNC Wood Router Parts Rust Free
After using cnc wood router for a while, you must will think that how to keep some parts of cnc wood router rust free? Here introduce some tips.
Oil Lubrication
When you works on metal material, better use oil to cool down cutter, since the coolant tray may is metal, not steeless. and this oil could act as a rust preventive.
Shavings
Metal shavings collect in all areas inside the machine enclosure and, if ignored, can hold moisture and cause rust. Most cnc wood router have a conveyor to remove the bulk of these, but care should be taken to clean hard-to-reach places. Even if the shavings are a material that won't rust, they can cause metal parts in the cnc wood router to corrode.
Daily Cleaning
Keep clean the cnc wood router after working. This is the daily job. Mist from coolant and dust from cutting processes settle on all areas of the machine, inside and out. The dirt and grime can build up and damage the finish of painted surfaces and cause bare metal to rust. Use a mild degreaser to clean up after each use of the cnc wood router, followed by an application of light rust-preventive oil.
