Hi guys,
I got one weird problem with a Makino milling machine with a Fanuc 0M control. The machine has 4 axis plus a spindle. The 3 axis servo drive display 0 (ready status), there is one dual-axis servo drive and 2 single-axis servo drives. The spindle drive displays - (not ready status, I think it will show 0 as soon as all references are completed and spindle is ready to move).
When moving the y-axis and z-axis, no problem, everything works as normal. The rotating A axis has to remain clamped as long as all other 3 axis have not be homed.
Now here is the issue: X-axis does not move whatsoever, but there are no alarm whatsoever being displayed. Furthermore, the currently displayed machine position does change while we are moving, but goes back immediately to the original value as soon as the X motion command is stopped. Parameter 504 (X-axis deviation allowed) is set to 10000, but even when modified to a very low value no alarms occur, it is as if the control knew that we command a displacement, make the number move on the screen, then realizes nothing moved, just goes back to the original position.
As for the encoder, as far as I know an encoder doing this kind of issue would very quickly display an X-axis displacement excess error as soon as deviation above what is set to parameter 504 is made.
As a quick note, when doing reference to X-axis, the value on the screen moves until it goes to OT+, then when it stops moving it goes back to original value, with no movements having been actually done. A simple reset removes the alarm.
Thanks in advance!
Edit: The only theory I could think of so far is a burned out servo motor. I've never seen a burned out servo motor before, don't know if it shows signs when there is deterioration (smell for example, there is no particular smell in this case) and don't know if it would give an alarm somehow. Thanks for any clues.
