585,971 active members*
4,059 visitors online*
    Feb 2008
    Cool Huanyang inverter
    Hi I'm having problems with the programming of the Huanyang inverter. I think I have the wiring right, but I cannot programme it.
    I was instructed to set the following:
    PD0013 to 8
    PD005 to 400
    PD004 to 400 and
    PD003 to 400
    I press the prog button then the up value till it reads Pd0013
    put I cannot input the 8
    I would be most grateful if you could help with how to use the keypad
    This link displays the image of the unit
    http://www.jinlantrade.com/Stock%20files/0008.jpg
    Feb 2009
    6028
    Make sure PD0 is set to allow parameter changes.
    Scroll to the parameter you want (PD13)
    Press the set button
    Value will be displayed
    Change to value you want
    Press set and hold for 1 second.
    Youll see it store.
    Drive has to be off, as in not running.
    Just set up my dads yesterday with the variable 10K pot.
    Jun 2007
    3757
    Follow the cryptic instructions in the manual.
    HuanYang VFD user manual.pdf download - 2shared
    PD000 is Parameter Lock. On page 26.
    It seems that you are classed as non-maintenance personnel !!
  1. Huanyang VFD Inverter all available Error Codes
    By Saintstone in forum Phase Converters
    Last Post: 07-08-2017, 11:26 AM
  2. Help with Huanyang HY02D223B
    By stevespo in forum Spindles / VFD
    Last Post: 02-01-2014, 09:42 AM
  3. Help Help Help - Huanyang VFd and spindle
    By PsychoPig7 in forum Phase Converters
    Last Post: 06-19-2012, 09:54 AM
  4. Huanyang VFD HAL Component
    By scotta in forum LinuxCNC (formerly EMC2)
    Last Post: 08-31-2011, 04:53 PM
  5. Huanyang HY02D223B goes POP!
    By stevespo in forum Phase Converters
    Last Post: 09-26-2009, 08:12 PM
