Many oil filters may need heat to separate the water from oil, but sometimes the oil may contain additives, so if you heat,the oil may become degradation or deterioration. then for this oil, you need choose the oil filter that don't need heat.
Zhongneng is the is a leading oil purifier manufacturer in China, which engages in developing, producing, selling a series of oil purifier such as transformer oil purifier, turbine oil purifier, engine oil purifier, lube oil purifier and so on, and zhongneng has developed a special oil water separator which don't need heat, but it can still remove the water from oil effciently, and this separator is the TYB Diesel Oil, Gasoline Oil and Light Oil Purifier.
TYB is one of popular oil filters of Zhongneng, it integrates fine filter, high efficiency demulsification and dehydration into one body, it can remove large of water without heating, creates the fastest dehydration speed in domestic at present.
This machine is specaiily designed for the fuel oil,gasoline and light oil, it can quickly separate water from the these oil, which even contains half water, to attain cleanness of NAS 6 grade. All in all,the TYB is be used for fast removal of water and impurities in fuel oil or light oil which contains large amount of water.
Some advatages about the TYB oil water separator
1,Because there is no heating, the additives in the oil are well prevented from degradation or deterioration.
2, This machine need low operation cost,20%-40% lower than vacuum purifier, centrifugal purifier and filter press.
3,TYB oil purifier is also easy to operate,water can be discharged online automatically without the presence of operators.
4,TYB series purifier adopt special oil water separator which requires no heating, offering 20 times higher water removing efficiently than over other types of purifiers.
Contact :Lilian
Email: [email protected]
Email*Google talk: [email protected]
Yahoo messenger:[email protected]
MSN: [email protected]
ICQ:619506345
phone: 086-15123344963
Keywordsil filtration, oil processing, oil filter, oil purifier, oil recycling, oil treatment, oil regeneration, oil restoration, oil filtering, waste oil disposal, oil reclaiming, waste oil management, energy saving, oil reconditioned, oil reconstituted, oil restituting, oil recovering,cheap oil filter,oil purification plant
