585,898 active members*
5,413 visitors online*
    Sep 2011
    474
    Circular bolt pattern wizard question
    Hey guys,
    Total noob here. I just finished building and calibrating my machine and need to make a lathe chuck adapter with a circular bolt pattern. Its a disk of mild steel 5" in diameter and I need to drill 3 holes to mount it to the chuck.
    Lets say I need to make a 3-hole circular bolt pattern 3.5" across with a .5" drill bit. The holes will be .5" deep.
    How would I enter this into the wizard? I may be able to ape my way through it but am afraid of breaking something since this is unscheduled and I have not yet installed my limiting switches on the mill.
    Thanks!
    Jan 2007
    243
    well for the pattern x,y coordinates you may want to try this program: Bolt Circle Calculator
    www.WebMachinist.Net
    The Ultimate Online Source for Machinist Related Stuff!
  1. Circle With Bolt hole Pattern
    By JJsFab in forum Torchmate
    Last Post: 09-01-2013, 06:07 PM
  2. Broken Tap in 2nd of 8 hole Bolt pattern
    By Kennebec in forum SIEMENS -> GENERAL
    Last Post: 02-27-2012, 11:00 PM
  3. circular pattern
    By timothy svec in forum Rhino 3D
    Last Post: 05-09-2010, 04:23 AM
  4. programming bolt hole pattern
    By jrogus in forum CNC Machining Centers
    Last Post: 05-23-2008, 07:23 PM
