585,996 active members*
4,544 visitors online*
Thread: Need Help!
Results 1 to 13 of 13
    Jun 2012
    Unhappy Need Help!
    Good morning.
    I got a Mecanumeric MF1525 three axes as part of payment of a debt from a client. After assembling the cnc and to initiate the session, I realized that the program was on the computer was very basic and it gave error when running the mill. I contacted the manufacturer who kindly sent me some books, unfortunately inconclusive. I tried running a program and failed. However, I tried to open them to realize that one programming language used and had no success. Does anyone here know this manufacturer and can help me?
    Aug 2005
    14
    Hi
    We have a Mecanumeric MF 1525 manufatured in 1999 running Plateforme software, wich is the one that came with te equipment.
    What kind of error are you experiencing? I know that Type3 wil run that machine, and also ArtCam, yet I think the machine comes configured to communicate in "MECA" language but you may change it to ISO.
    May 2013
    hi
    i have problem with instalation of my mécanuméric mf1525 system don't detecte it some one have drivers please
    Aug 2005
    14
    What Software came with the machine? It uses Serial Port doesn´t it ? The original Software fo that equipment is Plateform , and optionally Type3. I don´t think software can recognize that equipment that easily...
    May 2013
    Quote Originally Posted by PedroS View Post
    my problem is a virus crash my pc and i haved tu format so i lost all data i used mécanuméric FM 1525 with TYPE3 now i install type3 and that not recognize my equipme,t i need to new if that equipement needs drive tu work
    think's for ur help
    Aug 2005
    14
    I think Type3 already has it on it´s own post processor , yet you have to configure your equipment and comunication parameters... T think these are:
    Lenght:2520mm Widht:1520 X Axis resolution:125 Y Axis resolution:125 Z Axis resolution:200
    COM:
    Speed:4800bits Parity:None Bits Number:8 Bit Stop:1 Flux Control:Hardware
    I think you should try to find in the PProcessor something like "Meca" "Mecamatic" "Meca 3d"...
    Feb 2009
    23
    Goodmorning ,can any of you gentlemen have the manual of this cnc in english .I have bought one but it needs to be fixed since it got burnt(y axes and z axis).In order to proceed i need a manual regarding the electronic side of the machine.
    Regards
    Giorgos
    Dec 2013
    10
    Mecanumeric
    Quote Originally Posted by FredHonorio View Post
    Good morning.
    Te puedo alludar si me escribes en Español,
    Mar 2014
    Bonjour Pedros
    j'ai une Mecanumeric MF 1525 qui fonctionne avec type 3 (2D) , je demande de m'aider de modifier langage de cette machine en langage iso , et est ce que possible d'adapter mastercam sur cette machine si oui comment fait-il ?
    merci
    [email protected]
    Mar 2014
    bonjour
    j'ai une Mecanumeric MF 1525 , qui fonctionne avec type 3 (2D) , je veux usiner des moules en 3D , pouvez-vous m'aider de modifier le langage de cette machine en langage ISO et d'adapter mastercam sur Mecanumeric MF 1525.
    merci
    Mar 2014
    Re: Need Help!
    Buenas a todos, yo he conseguido el programa TYPE 3, pero necesitaria el manual de instrucciones d ela maquina ya que se le enciende una Luz Roja en el cabezal, no se a que corresponde, si alguien dispone de manual le agradecería que me lo pasara para poder ponerla en marcha, si alguien necesita el programa TYPE 3 solo tiene que pedirmelo.
    Un saludo a todos
    Oct 2015
    Re: Need Help!
    Bonjour
    j'ai le meme probleme du pilote MF1525 si vous avez une solution SVP
    Dec 2012
    6
    Re: Need Help!
    Goodmorning ,can any of you gentlemen have the manual of this cnc in english .I have bought one but it needs to be fixed since it got burnt(y axes and z axis).In order to proceed i need a manual regarding the electronic side of the machine.or elctric digram
    Regards
    Giorgos
