Great forum guys! I am thinking of building/buying a laser system to cut 1mm Aluminum, mild steel, and acrylic sheets.
I thought about getting a CO2 laser system that would be versatile and be able to cut the mild steel and acrylic easily. I found out that it would be borderline for the aluminum since it is reflective at the wavelength. Further research showed it is possible to do it at a minimum of 200W with oxygen assist. >400W would be ideal probably.. Looking over several vendor, a reliable laser at that power would be the Synrad firestar f series with their beam delivery solutions maybe.. I need to call them for prices..
Does these sound right guys? Any other suggestions on how else I should proceed? Any build thread you can recommend?
