Hey Guys, I recently bought 3 of the following motors from Automation Technology Inc..
High-Torque Stepper Motor, Stepper Motor, Driver, Stepper Motor kit, DC Servo Motor, DC Servo Motor kit, Stepper Motor Power Supply, CNC Router, Spindle, and other Components. Automation Technology Inc
two were purchased first and are working fine, however the third one was deleivered about 3 days ago and only after I installed it in the machine I began having problems on the Z axis in which it was installed.
after inspection the motor turns with the stepper indentation but kinda hard, and if you give the shaft a quick rotational snap it frees the movement up, however when the motor is connected back, as soon as the stepper signal in applied the motor siezes again.
I think the rotor assembly is touching the winding assembly and was wondering how to fix this? the bearing does not give any noticable play and I was thinking of sanding the inside of the motor assembly to see if that will help (probably the tolerance to the rotor is too tight)..
The company is not replying to my emails in a timely fashion and I need to finish this project, I have a great deal of time and money invested.
Thanks in advance for any help guys, and look out for the build thread with pics soon
