I've made several projects recently where I've carved a model and then put V-carve text on a flat portion of the model. In order to set the starting height of the text, I've cut the model and then either read the DRO for the Z axis as the flat portion of the model was cut or measured that area after then cutting was done. I then entered this into the Aspire program as the starting height for the V-carve tool path and everything works fine.
It's kind of a hassle to do this and it's difficult to prepare preview images.
Is there a way to get this height information from Aspire itself?
Here's an example of the projects I'm cutting:
