This arrow 500 I have is going to be the death of me, if it's not one problem its another.
I've just got a good handle on operating it, managed to machine up a good few parts. However now the spindle is going a bit crazy - any thoughts or comments on how the system works would be greatly appreciated.
The spindle will bang backwards and forwards violently, it sometimes runs smoothly for a few seconds, however not running at preset speed, mostly violently hunting for speed and reversing it will then just alarm out.
Another alarm it will have is when aligning it will error with Datum search error but it's turning fine several revolutions.
The controller is a CT FNC, The spindle drive has recently been replaced with a second hand unit that has worked well for a couple of weeks. Spindax spindle controller.
The machine is setup for rigid tapping, I havent quite figured out how the computer gets its signal yet - frm looking at cabling diagrams etc it looks like the resolver is going into the spindle drive which it commutates off, then interpolates an encoder output for the FNC?
I've continuity tested the cabling/plugs from the resolver to the spindle drive and from the spindle drive to the FNC - all appears good.
Has anyone seen this before? Any ideas? Does it sound like the resolver is gone?
