585,969 active members*
4,463 visitors online*
Results 1 to 7 of 7
    Sep 2005
    229
    3d dxf toolpath to gcode converter
    Is there any such program? I have searched but not found anything but bad 2d converters :P
    I want to just draw a 3d polyline in my cad program and have it converted to gcode, nothing else! 2d won't do, I want FULL control over the toolpath! :boxing:
    I'm thinking of writing my own converter, should be extremley simple (i havent read the specification for dxf yet) But please tell me if you would know anything worth checking out!
    /Jay
    I wrote an AutoCAD macro that will do what you want in AutoCAD. Does your cad program have VBA? If so, it's not too difficult to do.
    Sep 2005
    229
    I just started making a c++ console program... Almost finished
    But i have been thinking of writing a plugin/script for Rhino. I belive rhino use Vb script!?
    Perhaps you could place points along the toolpath with extra info, like if the layer name is feedrate: 55 the script would put a feedrate change at that position. And other things like pause, tool: 5, cooling: on and spindle: off
    /Jay
    I took a quick look at Rhino's VBScript. It doesn't look like you can access vertices through it, which you probably need to do. If you know C++ (I don't), download the Rhino plug-in SDK (free) and write a Rhino plug-in.
    In AutoCAD, I save extended data with each object to control things like feedrate, plungerate, depth/cut, depth/pass, ramping....
    Sep 2005
    229
    I have made a rhino script now!
    I solved the problem by interpolating points along the toolpath curve, you just specify the distance between the points, work fine!
    Sep 2005
    229
    Exclamation
    I have uploaded my rhino script now if anyone is interested!
    http://www.cnczone.com/modules.php?n...viewfile&id=67
    Apr 2009
    Quote Originally Posted by JBV View Post
    Hey, Jay,
    I haven't tried Rhino yet and I could really use this exact function. Could I possibly get a copy of your standalone version? Source is preferred (especially if you haven't finished it )
    Thanks!
    -Amos
