585,763 active members*
4,408 visitors online*
Results 1 to 9 of 9
    May 2009
    1332
    What motor HP is this one?
    A friend gave me the attached drive and DC motor for my Taig spindle. I plugged the drive to 120VAC, connected the motor and it works including the variable speed on the drive.
    I found the drive specs on the net and is included here if needed. But I can’t find any info on the motor particularly the HP or Watts. On the motor I can read the following: Electro-Craft Servo Products, Reliance Electric, Model E543, Serial # xx55748 (cant read the first 2 digits), Type X, Part #
    543-011-0740, Customer Part # 4027126-04.
    Anyone knows this motor or how I can find its power?
    Attached Thumbnails Attached Thumbnails DSC03705.JPG   DSC03707.JPG   DSC03709.JPG
    Attached Files Attached Files
    Nicolas
    24220
    Going by the E series it would appear to be around 60-70ozin continuous torque and 6000rpm.
    The frame size also points to high rpm.
    Electrocraft made many motor to OEM standard so the exact type does not always show up in the ElectroCraft catalogues.
    That controller is 3hp max on 240vac supply, but typically the E540 series were 60vdc.
    Al.
    Albert E.
    May 2009
    1332
    Any idea what the 60-70ozin continuous torque will be in Watts or HP Al?
    I just wonder if it will be capable to drive the Taig spindle. I dont want to do all the motor modification to attach it and find out that it is not worth it
    Nicolas
    24220
    The recognized conversion at 6000rpm would be around .6hp to .8hp.
    But this is just a rough conversion, as HP is dependent on rpm.
    Al.
    Albert E.
    May 2009
    1332
    That is encouraging and I will give it a try
    Thank you
    Nicolas
    Nov 2005
    For motor specifications please see
    http://www.cnczone.com/forums/genera...ed_servos.html
    May 2009
    1332
    Thanks for taking the time Bent to point me to this useful thread
    Haven't used this motor yet but I will one of these days
    Nicolas
    Going by the E sequence it would appear to be around 60-70ozin ongoing twisting and 6000rpm.
    The structure dimension also factors to great RPM. I just wonder if it will be able to generate the Taig spindle. I don't want to do all the engine adjustment to connect it and discover out that it is not value it
    Sep 2013
    4
    normally speaking, 1HP=0.8KW
  1. Replies: 4
    Last Post: 09-08-2011, 11:41 PM
  2. Replacement Motor Brushes For Sherline Mill AC Motor
    By Lessons in forum Benchtop Machines
    Last Post: 07-17-2010, 02:34 AM
  3. Problems with motor stalling due to motor/lead screw alignment
    By Bimmerkc1 in forum DIY CNC Router Table Machines
    Last Post: 01-25-2010, 01:12 AM
  4. Mach3 , Config, Motor Tuning problem ( FILM OF MOTOR)
    By MDF_Markazi in forum Mach Software (ArtSoft software)
    Last Post: 04-30-2009, 08:15 AM
