Originally Posted by
TurkishDelight
It's not really wise to cut 10mm acrylic with a 60W laser. 100W,120W or even 150W will be much better for cutting. On the other hand, your 60W Laser's main purpose is engraving and Lasers higher powered than 80W aren't much suitable for engraving. So it's either one or another. If you're going to cut thick stuff frequently, it's best to buy a higher power laser and keep your 60W laser for engraving jobs. A 100W/120W/150W laser tube won't fit in your machine and your Power Supply isn't strong enough either. So an upgrade is a no-no, just buy a new machine for cutting if you're going to cut thick stuff frequently. Otherwise, there's always Outsourcing.
