585,937 active members*
3,999 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Morbidelli Author 503 (1995) Tria 7500
    Jun 2011
    Hi all.
    Is there anyone who can tell me if you can use G code X Y Z generatet from PC then transfered to the CNC by floppy disk?
    example would be nice
    I ask because right now we program directly on the CNC point to point and we use autocad to get the point to points and then punch them in manualy and some of the programs are very very long so it would be good to have a program where you can import the autocad drawing and generate the X Y Z and just copy it to a floppy disk and load it as a SUB program.
    Any ideas is helpful guys.
    Best regards
    Flemming
    Jun 2006
    10
    Tria 7500
    Aspan 4 or later version off Aspan would do. Alternative could be Xilog.
    Feb 2006
    19
    Hi There,
    Did you ever find a solution? You could type the program on a PC using Notepad and then convert the txt file to binary using the morbidelli converter program CNVRT.EXE
    The .PGM which is not text can then be loaded from the floppy disk
  1. Tria 7500 for Morbidelli Author 503
    By stoned in forum Controller & Computer Solutions
    Last Post: 03-28-2024, 07:58 PM
  2. morbidelli 504 tria 7500
    By rprman1 in forum Commercial CNC Wood Routers
    Last Post: 08-09-2023, 07:03 AM
  3. Tria 7500
    By num1040 in forum CNC Machining Centers
    Last Post: 11-30-2019, 03:12 PM
  4. TRIA 7500 software missing
    By pablogvivo in forum Controller & Computer Solutions
    Last Post: 01-07-2014, 09:45 AM
  5. 'Errore Generico' Morbidelli tria 7500
    By fmorandini in forum Maintenance DIY Discussion
    Last Post: 11-03-2013, 06:48 PM
