(my English is not native, sorry if mistakes)
After a year and a half CNC machining with 3 axis, I aimed to upgrade to the A axis. I ordered a 4th axis motor and mechanism from ebay and got it (on NEMA 23).
Next I ordered an axis controller based on TB6560AHQ and the same as controllers that are running my X, Y and Z till now. The driver came and I jumped to assemble it. After hardware and software setup on inside the control box and Mach3, I went for a test and I found that the motor is rotating only on one direction. The other one does not physically work, although Mach3 is changing the coordinate.
Next I went for some trouble shooting. I first excluded the new controller, and the old stepper running on x and connected the new stepper to x. Test passed. Next, I tried to run my old stepper motor which is working properly, with the new controller: the same result: one direction works, the other not.
I did some other tests by including and excluding components and my overall conclusion is that the controller board has problems.
I will reorder one from ebay but on a new design I've seen there, but I thought to ask in this forum:
1. May be experts could help me make sure about the problem of the controller and even fix it?
2. Is there any reliable/proven schematics based on TB6560AHQ to DIY a driver board? I've milled successful PCBs and I think someone already proved a schematic for TB6560AHQ to work accurately with Mach3, but until now googling did not give a good result to me. Excep this one:
CNCRouterBuild: StepTB6560 Step Motor Driver
But I think there must be better options to implement TB6560AHQ, with additional circuitry usually found on professional stepper drivers.
Thanks in advance for advices.
