585,712 active members*
4,080 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Look ahead (GI) adjusted machining time estimation
    Feb 2011
    (Not sure if this is the right section)
    I work at a job shop where we have 5 CNC milling machines. We do a lot of varied work and very little production work, hence it is very important for us to be able to predict the machining time within 5-10% accuracy, as it has a lot of impact on scheduling as well as quote calculation.
    The machining time is largely off from the CAM software's predictions mainly because of the feed variations introduced by the controller's look ahead (Geometrical intelligence) function.
    So I want to know if there is any way of deriving a more realistic estimation of machining time? Do the controllers have in-built simulation which i can use to get the timing data before actually running the program? After all its not like the controller varies feeds based on any feedback signals, if I'm not wrong.
    Apr 2006
    3206
    Buy better CAM software.
  1. run time estimation
    By rsm169 in forum NCPlot G-Code editor / backplotter
    Last Post: 08-04-2009, 04:12 PM
  2. Axis movement speed adjusted by pressure sensor
    By Viesturs in forum Controller & Computer Solutions
    Last Post: 05-20-2009, 12:44 PM
  3. time estimation
    By camtd in forum FeatureCAM CAD/CAM
    Last Post: 04-23-2009, 10:56 AM
  4. Machining Time Off
    By extanker59 in forum CamWorks
    Last Post: 11-25-2008, 03:42 PM
  5. Run time estimation
    By barbter in forum NCPlot G-Code editor / backplotter
    Last Post: 08-04-2008, 04:54 PM
