586,011 active members*
5,002 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > J 325 bufferd input (Drip Feeding)????
    Dec 2010
    46
    I have been trying to drip feed my J 325 with no luck!! I have went into catalog mode, and typed in RS232C,then I hit mode select, then 1 for auto mode, then cycle start and when I hit cycle start it says fault 136 premature end. am I doing something wrong??? I can load programes with no problem but I would like to be able to drip feed so I can run bigger ones!! I am running Bob Cad V24
    Dec 2010
    46
    No one??? anything??
    Jun 2004
    42
    you didn't give enough information such as what control is on your machine. Different controls need to see ?????? Whatever. Try providing all the info and someone will try to help. There are a lot of knowledgable people on the "Zone"
    Dec 2010
    46
    It has a dynapath delta 20 control on it.
    Dec 2010
    46
    Thanks to Paul at Dynapath I got it working!! I had to change the eprom to an eeprom and reload parameters. unlimited lines of code now!!! lol
  1. Drip Feeding?
    By Fighter in forum Dynapath
    Last Post: 04-30-2013, 10:27 PM
  2. drip feeding
    By anddy26 in forum G-Code Programing
    Last Post: 10-14-2011, 05:47 PM
  3. Drip Feeding
    By widgitmaster in forum Polls
    Last Post: 01-28-2011, 09:02 PM
  4. drip feeding
    By stevieboy in forum HURCO
    Last Post: 04-21-2010, 09:05 PM
  5. Drip Feeding
    By Andre' B in forum Uncategorised CAM Discussion
    Last Post: 10-27-2008, 06:40 PM
