585,942 active members*
3,204 visitors online*
    May 2012
    cycles with sinumerik 810d/ 840
    hi all!!i need your help!
    i am trying to create a post processor for dmg50 3+2 axis cnc machine with sinumerik 810d for my master thesis, using pro/engineer 5 (creo 1).
    the machine recognizes the cycles with the format, for example, CYCLE81(RTP, RFP, SDIS, DP, DPR) for drilling instead of G81.
    In the option file generator in proe 5 there is an option for siemens 840 (motion->cycles)
    But with siemens 840 the code for tapping for example is with the following format:
    CYCLE84 (15,0,15, ,21,2,3, ,.005,0,300,300, ,0,0,0,0,0)
    and i need CYCLE84 (15,0,15, ,21,2,3, ,.005,0,300,300)
    So there are 6 parameters that the machine with control 810 can not read.
    the same is for CYCLE 83 etc, only for CYCLE81 the format of the code is compatible.
    how can i fix that??
    is there a way??
    or the solution is to change the FIL language?and how can i do that??
    Feb 2018
    Re: cycles with sinumerik 810d/ 840
    i have also same problem i want post file of sinumerik 810 post proceser file of delcam powermill10 & mastercam x9 post file can you help me
  1. cycles with post processor to sinumerik 810d
    By popi in forum PTC Pro/Manufacture
    Last Post: 07-09-2012, 01:26 AM
  2. cycles with sinumerik 810d
    By popi in forum Post Processor Files
    Last Post: 07-09-2012, 01:10 AM
  3. sinumerik 810D
    By popi in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 05-22-2012, 11:53 AM
  4. sinumerik 810D with pro/engineer
    Last Post: 05-16-2012, 01:12 PM
  5. Sinumerik 810D Postprocessor
    By jymdman in forum EdgeCam
    Last Post: 09-03-2009, 02:35 PM
