Originally Posted by
matt382
Alan,
You can control the feed/rapid rates through the V-carve software, but you have to set your machine to read those. It most likely came from the factory with this feature disabled. I don't recall off the top of my head if it is a setting in the inverter or in the DSP. Either way it is a one time step and then you'll never put it back. If you don't find what you need in the DSP manual than the answer is in the Inverter manual. You can find your Fuling inverter manual online.
The spindle speed is not controllable through the software with a DSP machine and is a common complaint that is not going to be addressed by the manufacturer. Only thing you can do is assign separate tool paths each time you need to change the speed so that there is a break in the operation for you to manually do so.
Matt
