Hi Guys,
I am importing reliefs from Cut 3D into V Carve Pro for a guitar neck.
The exported file shows the maximum height in Z of the model (25.4mm)
The model seems to sit on the X Y plane in the correct position. (0-0)
The material I am cutting the neck from is 30 mm thick.
Do I set Z-0 at 30 mm,(the top of the maple blank) or 25.4 mm (the finished high point of the neck carve)
I tried a test on a piece of 30 mm foam zeroed at 30 mm, but it cut 5 mm above the finished height. I cant take a very accurate measurement from foam, but it SEEMS to indicate that I need to set Z-0 manually to the Cut 3d figure.
What is the correct set up procedure?
