CNC wood router using is for speed up production, improve product qautliy. Well, some times, unproper operation would cause material waste because of misplace and even takes more time to complete the workpieces.
Here are some tips for cnc wood router operation tips.
1. Check if clamps are unsuitable or abrased. The abrased badly clamp may cause misplace of workpiece or cnc wood router in the process of engraving.
2. For unregular workpiece, you may see that it is fixed tightly, when it under the down force may could swash back and forth. Now, you could try to add some spent material for increasing friction, and also keep the unregular package with one piece of belt for easily be fixed. Or using clamps to fix its regular part, keep unregular part unfixed.
3. Clamps usually are with metal material, may damage the workpiece on cnc wood router, so you could use it with rubber hat or rubber pipe for touching workpiece.
