I'm trying to figure out how what size beams I would need to hold a distributed load. The structure is 40 feet by 10 feet.
Length of beam is 16 feet. 3 feet of that beam on each end is supported by an earthen structure underground. So the actual load is only on 10 feet. The load is 35,000 pounds per beam and I will be using 20 beams.
I will have the 20 beams separated every 24 inches to hold the overall load. The overall load above the structure is 660,000 pounds. For saftey I will make it an even 700,000 pounds.
What size beams would I need to have a center deflection of only .5"?
