585,997 active members*
4,847 visitors online*
Results 1 to 6 of 6
    Jan 2010
    20
    mach 3 error code 9991
    Hello everyone, I can`t get mach3 to run my gcode, every time I try to start the program it comes up with a error saying: Error found. Art code: 9991, atttempt recovery. is it mach 3 causing problems or could it be my pp.
    I am sooooo close anyone please help
    Best from Denmark
    Jan 2010
    20
    I Also have another problem. I cannot get mach3 to start my spindle with an M3, I have tried both M3 and M3 S8000 but no luck. I can turn on the spindle once, by using the spindle toggle when I have done that once I have to reset mach3 again. It has all been working before i connected some pcb touch plates,
    Any thoughts??????
    May 2014
    Re: mach 3 error code 9991
    Same error whenever I try to tune the motors. :-(
    May 2014
    Mach3 USB. Remove unnecessary plugins from the Mach3 folder. Worked for me.
    Quote Originally Posted by Jincamty View Post
    Can you indicate which are the necessary plugins please?
    Jan 2018
    Quote Originally Posted by digifabcnc View Post
    For mine is was NVEM_NEW.dll
    I had been using the updated 3.0 version of the file anyhow.
  1. Alarm 9991?
    By Blakea1790 in forum Mach Mill
    Last Post: 07-19-2013, 01:57 PM
  2. g code error with image to g-code
    By cruzin in forum LinuxCNC (formerly EMC2)
    Last Post: 09-05-2012, 11:34 PM
  3. VFD Error Code, Mach 3, PWM
    By Jet A in forum CNC Machine Related Electronics
    Last Post: 05-28-2010, 06:18 AM
  4. Mach III Komo Error Code
    By pip10780 in forum Commercial CNC Wood Routers
    Last Post: 01-13-2009, 05:45 PM
  5. mach 3 error
    By genexis in forum Mach Mill
    Last Post: 06-19-2007, 01:53 AM
