584,863 active members*
4,709 visitors online*
Results 1 to 10 of 10
    Jun 2012
    Mori Sieki MV-45/40 VERTICAL MILL
    tool chuck dropping out, It seems push rod and the draw bar are pushing the collet out enough to collect the pullstud of the chuck and it is not engaging correctly we recently replaced the bellvel washers and collett and it cured it but only for a few month if we screw out the pull stud 1mm its ok but this isnt practical for all our tooling is there anyway of adjusment ? help would be appreciated ,thankyou
    Feb 2009
    6028
    Let me guess, you undid the hydraulic hoses on the unclamp cylinder when you did the springs.
    tool inserting problem
    I think it is a problem of draw bar adjustment problem. you may try this
    tool is not inserted into spindle,problem in drawbar, disc spring or collet.
    Apr 2005
    108
    Is your MORI is with a gear
    We have 4 mori 2 with gear the one with the gear dropping tool
    So we made some modification to the drawbar
    If you wants I will try to find what we made it was 2 years ago
    After this the problem solved
    Jun 2012
    thanks for your reply. Yes we did undo the hoses would this cause us a problem?
    Jun 2012
    Thank you for your reply. Yes its the one with gear i would appreciate your information of the part you made to solve the problem thanks.
    Jun 2012
    Thanks for your help i will go through everything on the list. thanks again.
    Apr 2005
    108
    first take your tool and put around the pullstud Plasticine this is kids stuf
    then insert the tool and lock it then release and observe the pullstud
    how deep the holder hold the tool in our machine we found that it allmost
    not holding it
    May 2012
    as underthetire hinted at previously, i suggest bleeding the air out of the charge tank/hydraulic system, a few bubbles in the lines is all it takes to keep the drawbar from completely compressing, allowing it to accept a tool. start at the charge tank and work your way way from it. ive bled this system before on our MV's, it can take a while, it also helps to run the spindle in between opening the bleeders.
    Jun 2012
    noticed arms on collet were slightly bent fitted new one problem solved . thanks again for all the help
  1. Parameters of MORI SIEKI SL25 B5, FANUC 10T, S/No. 695
    By ejaz199 in forum Mori Seiki lathes
    Last Post: 02-09-2022, 09:29 AM
  2. Mori Sieki Lathes
    By JACKOFTRADES in forum Mori Seiki lathes
    Last Post: 07-16-2012, 11:01 AM
  3. Mori Sieki MV 55 tool regestering
    By backintheday in forum Mori Seiki Mills
    Last Post: 03-01-2012, 02:48 AM
  4. Mori-Sieki MH630
    By Bluesman in forum Mori Seiki lathes
    Last Post: 11-19-2007, 11:53 PM
