585,705 active members*
4,475 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Homann Designs TM20LV (BF20,G0704) conversion
Page 16 of 16 6141516
Results 301 to 303 of 303
  1. #301
    Aug 2005
    1091
    Re: Homann Designs TM20LV (BF20,G0704) conversion
    The image below show the panel in place. You can see that input 3 is active due to the touch probe being plugged in. Note that the probe in connected to input 4 and and is not active.
    My next project on the mill is to install a power drawbar.
    Cheers,
    Peter
    Homann Designs - http://www.homanndesigns.com/store
  2. #302
    Aug 2005
    1091
    One other thing I did to disable the spindle when the probe is plugged in was to process input 3 that is indicating the phono jack is plugged in to input 4.
    I modified the M3 and M4 macros in Mach3 to check the status of input 3. The modified macros are below;
    M3 macro
    Code:
    If (Not IsActive(INPUT3)) Then
    	DoSpinCW()
    else
    	Message "Probe is plugged in"
    	DoOEMButton(1021)
    end if
    M4 macro
    Code:
    	DoSpinCCW()
    else
    	DoOEMButton(1021)
    end if
    I also changed the the button script for the spindle toggle button on the Mach3 pages that uses the button to the following;
    Code:
    If (Not IsActive(INPUT3)) Then	DoOEMButton(110)
    Else
    	DoOEMButton(1021)
    End If
    BTW OEMButton 1021 is the reset button, causing Mach3 to go into reset if an attempt to run the spindle when the probe is plugged in.
    Cheers,
    Peter
  3. #303
    Nov 2009
    4415
    Nice job, Peter!
    A lazy man does it twice.
  1. Optimum BF20 G0704 Conversion
    By Winnfield in forum Benchtop Machines
    Last Post: 08-07-2011, 12:16 AM
