584,857 active members*
4,452 visitors online*
    Aug 2004
    12
    Spindle speed for Sieg conversion
    I have a Sieg X3 converted and running on Mach 3, my question is about controlling the spindle speed with the variable speed board on the X3.
    The speed is adjusted by a 4.7K pot and has a switch for cw/ccw.
    Could I wire a relay to the output pins for CW/CCW and use PWM to emulate the 4.7K pot and use a simple encoder for rpm feedback?
    Jun 2004
    201
    Did you find the answer?
    I am also wondering how to do this
    Jun 2003
    1365
    yes, you could do that, you could use a digispeed for the pwm input and controller and a relay controlled by m3 m4 and m5 to controll the direction.
    I doubt its healthy to switch it while in motion though.
    Jon
    Jun 2004
    201
    I just emailed them over at http://www.homanndesigns.com/index.html about the digi speed.
    I'll let you both know what the get back to me with
    Aug 2004
    12
    I have been in touch with Peter Homann and he seems confident the digispeed is going to work, I have emailed him schematics for the X3 for further clarification.
    I'm going to order one, I'll let you know how it goes
    Randy
