585,996 active members*
4,838 visitors online*
    Jul 2012
    5
    Fagor 8025MG and error 064
    Machine: BRAGONZI 100/180 R with Fagor 8025MG
    Problem was battery loss which caused losing of machine parameters. There is no backup of parameters...
    First there was errors about M functions and G53/G59 and after filling those parameters these errors are gone and now when machine starts general test passed. But now when I want to enter manual moving of machine (OP MODE -> 5) we got error 064 EMERGANCY and we can't move machine...
    I tried to jumper 24V to pin 14 of I/O1 connector. Then I got on bottom row bellow M number 1 but and after turning off and then on machine I again getting 064 error.
    As far as I know, I think that is external error but that maybe pin 14 is wrong and that I need to know right pin. Or maybe just wrong parameters...
    I have tested all limit switches.
    I have all documentation but I don't have electrical schematics. I have found on the Internet manual for PLC but no progress.
    Does anyone know how to remove this error 064?
    Jul 2012
    5
    I still thinking that is problem with parameters.
    Does anyone know what parameters concerning to error 064?
    Or how to find correct pin for external emergency because I think that is not pin 14?
    Any clue?
    Dec 2011
    73
    Quote Originally Posted by axilos View Post
    Any clue?
    Theres a parameter in the 600 range (i think 605... but dont quote me on that) and it is related to the switching voltage for I/O. It could be like you're giving I1 24v to switch, but the control thinks it should be 0v or the other way around. If you can, double check for a parameter like that in the installation manual if you have one.
    And I do believe that pin14 is I1
    Dec 2008
    8
    Re: Fagor 8025MG and error 064
    Axilos,
    Did you ever find a fix for 064?
    Thank you
    Todd
  1. Fagor 8025m, ERROR 000 ???
    By ferrumdg in forum Fagor Automation
    Last Post: 11-01-2022, 12:04 PM
  2. Fagor 8055T Error 214.
    By soapcy in forum Fagor Automation
    Last Post: 12-16-2019, 11:56 AM
  3. Fagor 8040 Error DNC
    By Xavior in forum Fagor Automation
    Last Post: 07-20-2014, 07:34 PM
  4. help with fagor 8025-mk error 072
    By youngoak in forum Community Club House
    Last Post: 01-07-2014, 04:46 AM
  5. Fagor 8025ms error 064
    By diazosvaldo in forum Spanish
    Last Post: 11-21-2011, 03:23 PM
